I have an '89 Caprice 9c1 police car, that I swapped with my mechanic last summer (it was a lender car). It has an LO5 350 with a 700R4 tranny. I step on the gas, and it feels very loose, strained and not responsive. It shifts too early, is slow off the block, but is fine in 4th gear. Unless I'm in 4th, I really have to gas it pretty hard going up hills, and have to shift into overdrive or even 2nd sometimes on hills. It should feel much tighter and put you in your seat more.
The car has no other problems & is very reliable. I thought it might be the throttle valve, and it seems a little loose. I ran a fuel injector cleaner. Could it also be the fuel filter or torque converter? Tranny fluid has been changed. Please help! I don't wan't to risk damage to my tranny or anything.
Mar 7, 2009 at 2:47 PM
