It sounds like you have excessive wear in your timing set. Adjusting the timing is only an intermittent fix. Chain stretch is usually the culprit, which is very common in high mileage motors. Not an incredibly hard fix for the shade tree mechanic.
SPONSORED LINKS
Friday, June 13th, 2008 AT 7:22 AM
