1968 Chevrolet Camaro No Power Misfire
DEPUTYSTONEMAN
i have a 68 camaro with the 250 6 cylinder, 2 spd. power glide. i went out for a ride and bingo, it started running like crap. felt like it was running on 2 cylinders. lots of missing/back firing type noises. aboslutely no power on accelerating or pulling the smallest of inclines.
it has had a small backfiring problem when cold. but once warmed up it disappeared.
last month i timed it, new points, plugs, cap, wires. the neighborhood wrench set to carb. for me.
any ideas?
thanks for all your help.
Aug 12, 2007 at 9:14 AM
TEMPO NIGHTMARE
  • 5 POSTS
Hello
In 1968 as you mentioned
Your distributor has a set of points and a condenser. Make sure your gap is set correctly. As well as timing...To much timing and it spits back through the Carb... To Little timing and it back fires thru the exhaust...So , Be sure you have the correct timing :wink: ..Also check the Mechanical advance in the distributor. as the springs maybe worn out and or it maybe froze up...(Common occurance in that model year) Which is a common occurance when they sit for long periods of time. Or If it has vacuum advance check the Vacuum pot to see if it is operateing correctly... Pull the distributop cap off and disconnect the vacuum line from the carbureator and create a Vacuum. (sucking on the hose should suffice) you should be able to see the Vacuum advance plate move inside the distributor. if it doesnt move then replace the Pot. As long as the advance plate in the distributor is Operable. (If not replace the distributor)Or possibly get one from your local Hotrod Shop or have it reconditioned.... Because,With out it,As you accelerate the advance is what gives the motor power.. No advance No Power..Which cause stalling, spitting, Popping and Hesitation.. Or You may need to also re-set the choke. Depending on what state you live in. However, here in michigan in the older model cars you had to set the choke differently for winter and summer in those older model vehicles! :roll:
Hope this helps...Let us know...
and please donate to this site...Thanks!
Aug 12, 2007 at 3:11 PM
DEPUTYSTONEMAN
i pulled the distributor cap. the rubbing block, that is the black plastic piece on the points that rides on the distributor lobes looks flat. from the looks of it it does not look like that as the distributor turns the points would open.
would this cause a dramatic loss of power and the other symtoms?
Aug 13, 2007 at 8:27 AM
MERLIN2021
  • 17,250 POSTS
Crank the engine til you get the cam in the distributor to a high point on the (rubbing block) if the points don't open on a high point Regap them.
Aug 15, 2007 at 10:33 AM
DEPUTYSTONEMAN
i put new points and condenser in, gapped the points and it fired right up.
thanks for your help
Aug 15, 2007 at 12:15 PM
Suggested Repair
Replace the points and condenser and set the point gap so the points open on the distributor cam high points. If symptoms remain, verify ignition timing and that the mechanical and vacuum advance operate correctly.
Conversation Summary
A 1968 Chevrolet Camaro with a 250 six-cylinder and Powerglide suddenly lost power and began missing and backfiring. Advice focused on point gap, timing, and distributor advance. The owner found the points rubbing block worn flat so the points would not open, then installed and gapped new points and a condenser, after which the engine started.
