Engine Performance problem
2002 Chevy Camaro V8 Two Wheel Drive Manual 91k miles
I have a scanner with live data and the fuel trims are a little lean part throttle and wot and the spark plugs confirm a lean running motor. Also about a 4 mpg drop and lack of power. I have tried another mass air sensor, tps, fuel filter, tested fuel pressure=good, and different fuel additives to with the gas. Both sides are lean with the driverside showing leaner. 0 codes.
Mar 14, 2010 at 9:16 AM
