2002 Chevy Camaro Fuse Replacement
2002 CHEVROLET CAMARO
43,000 MILES • 6 CYL • 2WD • AUTOMATIC
HONOLULUBRYAN
I have just recovered my camaro from being stolen. It is in pretty bad shape due to what ever they did and I am trying to get it back into the correct working order. The fuse box was taken out and I have no idea what the correct amp/fuse is needed for every slot in the door panel fuse box. n Also, if you could help me with the engine fuse box fuse requirements I would greatly appreciate it.
Jan 17, 2010 at 11:20 AM
ERNEST CLARK
  • 1,730 POSTS
Unfortunately, I can't find a pictograph showing which fuse goes where inside of your fuse box. I was able to locate a wiring diagram that will show you the fuse amperages for each circuit. (If that helps) My suggestion to you is to purchase an on-line subscription to "Alldata" or "Mitchell 1". They're only about $25-$30 for a single vehicle and they'll show you exactly what you need as well as give you many repair procedures that might come in handy later. Also, you could go to a junk yard and locate an intact Camaro and purchase the fuse boxes for both the interior and under hood. Here's the wiring diagrams. The I/P is for the "Interior" and the U/H is "Under hood".
https://images.2carpros.com/forum/automotive_pictures/455169_2002_Camaro_Fuse_Block_1.jpg
Jan 20, 2010 at 12:38 AM
