2002 Chevy Camaro fuel problem
100,000 MILES • 6 CYL • 2WD • MANUAL
MJ WATSON
new fuel pump and still no fuel pressure
May 24, 2009 at 4:08 AM
JDL
  • 16,098 POSTS
Hello, did you do any testing before you replaced the pump? Any fuel pressure, you need a gage. Key on no crank, can you hear the pump run a little? Have a helper crank it while you check for good B+ and ground at the pump connector. With the engine cranking do you have good spark at the plugs and injector pulse? Any codes?
May 24, 2009 at 4:20 AM
MJ WATSON
no codes,no fuel pressure,put a pump in one month ago ran fine, then another one in drove around a little bit parked it.next morning same problem. just learned how to turn a computer on last night. thank you for anything to get me to problem. cant type either. thank you sir
May 24, 2009 at 4:39 AM
JDL
  • 16,098 POSTS
You might also check for voltage at the fuel pump relay. Key on and engine cranking.
May 24, 2009 at 5:45 AM
