1999 Chevy Camaro help
63,000 MILES • V8 • 2WD • MANUAL
GTAN
I bought a 1999 Z28 and the problem is the car is running rich and making the service engine light come on, code p1153 (02 sensor) and so I noticed that there are performance injecters on the car that are putting out 43 lbs of fuel an hour, so I put stock injecters on that put 24 lb of fuel an hour and the car just wouldn't stay running, so I found a vacum leak and replaced the seals and that didn't fix it, so I put the performance ones back on and it's ok, but I still have the problem of it running rich, could it be a ecm problem, mabey because he programed the ecm and the ecm don't register to the stock injecters. pls help
Oct 10, 2009 at 5:30 PM
  • 110,248 POSTS
The injectors are designed to supply more fuel. Because this isn't a stock situation, you have to bear with me. You said he adjusted the computer to accomadate the injectors. I have to question two things. First, does the ambient temp sensor recognize the additional fuel and can the O2 sensor know what to do with the extra fuel?
Oct 10, 2009 at 6:07 PM
