It means tht your right bank is running to rich. It can be a lot of things, check to see if your air duct going in to the throttle is blocked or partilally blocked, or if the MAF sensor is blocked or a hole in teh duct work or someting blocking the air filter. Also check to see if there is fuel in the fuel pressure hose vacuum line. also check for a vacuum leak on that side like a broken hose or cracked vacuum hose someplace. If none of those then take it to a pro because there are several things that need to be looked at and FREEZE FRAME data will be needed to taken......
Sep 24, 2010 at 11:37 AM
