1997 Chevy Camaro #3 cylinder Misfire
RESCUEFE
  • 1997 CHEVROLET CAMARO
  • 6 CYL
  • 135,000 MILES
I've changed the plugs, wires, coil (I even swapped between the 3 a 6 cylinder) and computer. The misfire is always in #3 and only at low RPM, less than 1500 RPM. Could it be the injector? What else can I look at to see what can cause it?
Sunday, May 18th, 2008 AT 2:12 PM
PRODRIGU
  • 26 POSTS
Yes it could be the injector. May also be a bad valve, since it is really noticable at low rpm, when you rev the eng. Up it seems to go away but really hasn't, its just masked by the speed of the engine. You may want to take a compression test on the engine.
Sunday, May 18th, 2008 AT 2:58 PM
