HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Camaro
Engine
Symptoms
Overheat
SPONSORED LINKS
1997 Chevy Camaro
ROBBRICHARD
MEMBER
1997 CHEVROLET CAMARO
Engine Cooling problem
1997 Chevy Camaro 6 cyl Two Wheel Drive Manual
high speed not working on radiator fans
check relays w/ test light & high speed kicks in
i guess the light is grounding the terminal
Monday, June 28th, 2010 AT 2:33 PM
ROBBRICHARD
MEMBER
SPONSORED LINKS
Monday, June 28th, 2010 AT 2:38 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1997 Chevy Camaro Overheating
1997 Chevy Camaro V6 3.8, The Car Has Had The Radiator, Water Pump, And The Thermostat Replaced. The Radiator Is Not Pushing Water Back...
Asked by
rortz21
1 ANSWER
1997
CHEVROLET CAMARO
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1997 Chevy Camaro
Engine Cooling Problem 1997 Chevy Camaro V8 Manual 90000 Miles Just Changed Radiator And Thermostat. Engine Still Starts To Overheat....
Asked by
Shelby Jenkins
1997
CHEVROLET CAMARO
I Have A Question About My Camaro 95 3.4l
The Car Drives Perfectly But The Heater Is Not Working And Where The Oil For The Engine Is Located There Is Steam Coming Out Of It But No...
Asked by
Ricoslider
4 IMAGES
1995
CHEVROLET CAMARO
1994 Chevy Camaro My Car Gets To Hot
My Camaro Gets Olmost At The Red On My Gage End Then The Fan Stars In. I Took The Termostat And Still Does The Same What Could It Be
Asked by
007juan
1994
CHEVROLET CAMARO
2002 Chevy Camaro Engine Overheating
My Car Keeps Overheating. And I Have Coolant Leaking Right Underneath The Air Intake. Could A Faulty Thermostat Cause Enough Pressure To...
Asked by
sachmoe
1 ANSWER
2002
CHEVROLET CAMARO
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Online car repair manuals
