1995 Chevy Camaro No idea whats wrong...
1995 CHEVROLET CAMARO
190,000 MILES • 6 CYL • 2WD • MANUAL
TWEEMS
It starts just fine when i first goto start it and i can drive it around and itll be fine but when i shut it off and try to turn it over a agian the only way i can get it to start is by holding the peddle to the floor. I swapped injectors, plugs, fuel regulator, mapping sensor, fuses and checked the fuel pump. Also cleaned off the air sensor.
Dec 19, 2009 at 11:53 AM
BEEF99
  • 152 POSTS
Sounds to me like it could be a coil issue or something electrical such as that.
Dec 25, 2009 at 9:57 PM
DKENT
Sounds like it might be the Idle Air Control motor and/or the Throttle position sensor. You might want to remove them and clean them with carb cleaner and try again. I did that to mine and it worked fine.
Dec 27, 2009 at 5:24 PM
