My 1995 Z28 has recent rebuilt heads,new plugs and ignition wires,a seven year old replacement cat converter,runs very good with no check engine light showing,but fails the smog test due to high HC reading at idle and cruise speed on the roller dyno.Can the oxygen sensors be the culprit even though the car has no trouble codes, or do you think the converter is more at fault?
Jan 30, 2009 at 4:21 PM
