1994 Chevy Camaro help if possible
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
92 LINCOLN 4.6
  • 12 POSTS
my 94 camaro 3.4 the car had a little miss and i cleaned the throttle ect. ran fine, now when i try to drive it runs ok until it starts getting warm it jumps around feeling it cuts out and some what makes a back fire noise an the tach/speed gauge will jump around and the car will qut.
Oct 18, 2010 at 6:21 AM
JDL
  • 16,098 POSTS
When the vehicle stalls, don't recycle the key, leave it on, check for primary voltage at the ignition coil, That is a smaller wire maybe pink, usually hot with the key on. Primary voltage won't hurt you, secondary voltage, thicker wires, will bite.
Oct 18, 2010 at 6:50 AM
