1994 Chevy Camaro gas smee and stall on deceleration
SRIBARRA
  • 1994 CHEVROLET CAMARO
  • V8
  • MANUAL
  • 77,000 MILES
I recentley purchased a 94 camaro z28. I noticed a strong gas smell when driving it and long afer parking it. It also idled kind of weird. When I decelerate the rpms drop to about 550 but then goes to 1000 on its own. Sometimes when the rpms drop it is not able to recover and stalls.
Friday, April 10th, 2009 AT 10:22 PM
Check the fuel pressure with a fuel pressure gauge designed for your fuel system and comeback with the readings we start here.
Saturday, April 11th, 2009 AT 4:20 AM
SRIBARRA
  • 5 POSTS
The fuel pressure is at about 45
Saturday, April 11th, 2009 AT 2:24 PM
SRIBARRA
  • 5 POSTS
I also checked the fuel injectors and all seem to be fine
Saturday, April 11th, 2009 AT 2:26 PM
Check the idle air control valve, throttle position/ mass airflow/map sensors to include the CPS.
Saturday, April 11th, 2009 AT 5:35 PM
SRIBARRA
  • 5 POSTS
Ive checked all the sensors, as per the repair manual, all working to spec, I also dont have the check engine light on
Sunday, April 12th, 2009 AT 2:41 PM
SRIBARRA
  • 5 POSTS
I found the problem, there was a cracked hose on the charcoal canister and this was what was causing the smell and bad performance. Just thought Id let others know in case they have the same problem
Tuesday, April 14th, 2009 AT 3:51 PM
