Is there a hose that runs from the moter to the tranny that could leak anafreaze
Saturday, February 14th, 2009 AT 12:04 AM
MECHANIC
If there's an antifreeze leak between the engine and tranny could be a freeze plug behind the engine-There's no hose from the engine to the tranny-unless the radiator transmission cooler is leaking internally and mixing with the tranny fluid and exiting out a leak in the tranny lines
