I would check the engine and tranny mounts, also tires and tire balance. If the shocks are bad the tires can actually bounce, this will wear a scolloped pattern into the tire tread, once this happens you will need new tires!
SPONSORED LINKS
Tuesday, July 29th, 2008 AT 5:54 PM
