If you were to by a 1991 L-98 350-cubic inch engine, then you could basically keep everything you have, but the computer would definitely have to be reprogramed.
It won't be able to compensate for the larger air/fuel demands of that motor.
Also, you may have to use larger injectors (Higher flowing) Other than that, small block motors of that era have completely interchangeable parts (External)
Now, it you buy an LT-1, you'll have to changed everything. You'll need to buy the computer, wiring harness, fuel and ignition system to go along with the motor.
Unless you are already familiar with that engine swap combo, I'd suggest you have a shop do an LT-1 swap.
Wednesday, January 6th, 2010 AT 7:16 AM
