1991 Chevy Camaro Radio
1991 CHEVROLET CAMARO
260,000 MILES • V8 • 2WD • AUTOMATIC
BRANDON55
I have a 1991 camaro rs...i recently put a new sterio head unit in it and i have no power to my unit. I checked thefuse box..i c no burnt out fuses.
Jan 4, 2010 at 1:17 PM
ERNEST CLARK
  • 1,730 POSTS
Are you sure the radio works? Also, you need to make sure your wiring was correct. And finally, check the in-line fuse that's in the red power wire that feeds the radio.
To check for power, you need a test light. Remove the red power wire and probe that for voltage. If there's voltage, then you need to check the ground circuit. If there's a good ground, then your radio doesn't work.
If there's no power, then probe the circuit backwards to the fuse box until you find a break in the wire or a bad connection. If you don't have a good ground, then find one in another location.
Jan 8, 2010 at 1:10 PM
CARADIODOC
  • 34,367 POSTS
Hi guys. Also don't forget there are two power wires. One for the switched power from the ignition switch and one that's always hot for the station preset and clock memory. Some radios are totally dead if the memory circuit is dead. Some work but have no sound.
caradiodoc
Jan 8, 2010 at 2:09 PM
