1991 Chevy Camaro heat problems
JAIMON.RICHTER
  • 1991 CHEVROLET CAMARO
  • V8
  • MANUAL
  • 135,000 MILES
My car will blow hot hot air out of the vents after about 15 minutes of driving. Wherever I turn the vents to it blows there. The controls can be set to cool or hot and on low but will still blow hot air. The farther I drive the harder the air blows.
Friday, April 16th, 2010 AT 11:58 AM
HMAC300
  • 48,601 POSTS
From what you describe it sounds as if your A/C isn['t working if you have it. Also there is a door that shuts the heat off and that may be stuck or not working. You'll neeed to feel around and see if it moves. One is for the vent/defrost and the other for turning the heat off/a/c on. Check those. They both may be vacuum or elelctric then you'll have to see if you are getting electric or vacuum to run them.
Monday, April 19th, 2010 AT 1:54 PM
