1991 Chevy Camaro
206,495 MILES • 6 CYL • 2WD • AUTOMATIC
COHIOGUY1
hello i have a 91 camaro when it gets up to 45 to 50 it wants to shake or viborate but if im constantley excelerating it wont do it or when im coasting it wont shake done replaced coil tps tranny filter fuel filter plugs it also wants to chug at the same speeds dont no what is going on do you think that the plug wires or the dist cap might be bad
Sep 14, 2009 at 8:52 AM
TEAG
  • 158 POSTS
You might want to check your end-link bushings on the sway bars. When those go bad it causes exactly the problem your having. It could also be a worn transmission mount or wheel bearings. If the engine runs good and dont seem to miss, I highly doubt its a problem with the engine itself. The cheapest way to start is to try the end link bushings. It most likely could be your problem. Ive done tons of these and only 1 out of every ten werent a bushing problem. Good luck!
Sep 28, 2009 at 8:22 AM
