when i turn my wipers or washer fluid sprayer on, the engine drops rpm?
1989 CHEVROLET CAMARO
ANDREW0360
when i turn my wipers or washer fluid sprayer on, the engine drops rpm and wants to die, but never does. and it seems to do it mainly when im accelerating. any ideas what the problem is?
Sep 4, 2010 at 12:06 AM
  • CAR REPAIR CONTRIBUTOR
This is due to one of two issues. Either your washer/wiper motor is drawing way too much current and dragging the alternator down or the alternator is failing and not able to keep up with the load.
So, this means we need to start with load testing the alternator so that we can make sure this is ok.
https://www.2carpros.com/articles/how-to-replace-an-alternator
If this is okay, then we need to check the current draw on the wiper motor. You can do this with an amp clamp to find out if this is the issue but normally this would blow a fuse if it is drawing this much current.
So, let's start with the alternator and go from there.
Let me know what questions you have, and we can go from there.
Thanks
Dec 23, 2021 at 2:49 PM
