1989 Chevy Camaro car wont pass gas to fuel filter
1989 CHEVROLET CAMARO
132,000 MILES • V8 • 2WD • AUTOMATIC
MGCAMARORS
  • 9 POSTS
my car wont pass gas to fuel filter, replaced fuel pump, fuel filter, fuel pump relay, but wouldnt start, then we took fuel filter off to see if gas was pumping to fuel filter and it wasnt, the fuel pump turns on for bout 3 to 5 seconds so we think its working just gas does not have any pressure ccoming up to even get to fuel filter just need to know what i ciould be.
Mar 30, 2009 at 11:56 PM
  • CERTIFIED EXPERT
Hook up a fuel pressure gauge and read the pressure-No pressure double check the fuel pump
Mar 31, 2009 at 12:03 AM
MGCAMARORS
  • 9 POSTS
thank for advice will do, just had some more questions could it have to do with something electrical, or a oil/fuel sending unit if so where is that located also some people said i could have a bad fuel or clogged fuel line coming out from tank cause the fuel pump has a strong hum when it turns on just trying to find if could be something else cause dropping that tank is no joke
Mar 31, 2009 at 3:27 AM
  • CERTIFIED EXPERT
The only way to tell is to check the fuel pressure even though the pump is humming.
Mar 31, 2009 at 2:22 PM
MGCAMARORS
  • 9 POSTS
got gauge could u give quick info how to use it how much pressure should hhave do i put fuel filter back on
Mar 31, 2009 at 8:46 PM
  • CERTIFIED EXPERT
What type of fuel system-Carb/TBI/MPFI?????
Apr 1, 2009 at 9:03 AM
MGCAMARORS
  • 9 POSTS
sorry its a 350 tbi
Apr 1, 2009 at 12:56 PM
  • CERTIFIED EXPERT
Read para 2/3 below
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_pressure_7.jpg
Apr 1, 2009 at 4:47 PM
MGCAMARORS
  • 9 POSTS
checkd pressure it kept marking 6 to 7 so i guss no pressure dont know what it could be
Apr 6, 2009 at 7:21 PM
  • CERTIFIED EXPERT
Is that 6-7 kg/cm2 or PSI?? if its psi the fuel pump is no good or the pressure is leaking somewhere such as the injector/s, fuel pump check valve and pressure regulator.
Apr 6, 2009 at 11:53 PM
