1988 Chevy Camaro no power to fuel injector
158,000 MILES • V8 • 2WD • MANUAL
KAMARO_2
hi i have a problem with no power to my 1988 CHEVROLET CAMARO V8 5.0 Liter FI injector . i spent i dont know how many hours to replace the fuel pump . i bought a tester to check the two fuel injectors and found no power . it will start some times . could it be the ecm ?
Feb 16, 2009 at 2:46 PM
  • 75,988 POSTS
Did you check both of the fuse 10amp? The white wire powers the left inj and red wire power the right-
If the fuses are okay and your getting power at the white and red wire from the injector. Your problem is the computer ground driver circuit.
Feb 16, 2009 at 6:58 PM
