1988 Chevy Camaro battery?
BLUCIPHER
  • 7 POSTS
Engine Mechanical problem
1988 Chevy Camaro V8 Automatic
I was having a problem where the car wouldn't idol by itself for the first minute after starting it, then it would run great. I unplugged the positve battery terminal and replaced the fuel pump relay. When I plugged the battery back in, I heard a high pitched sound coming from in the cockpit. This sound went away upon turning the key on, but now the car won't start. At first I thought maybe it was in the relay, but even with the old relay, it still wont start. It was running great, and I wouldn't have thought unplugging the battery would cause such an issue. Any ideas as to what it might be??
Jun 22, 2010 at 11:37 PM
INTERNETMECHANIC
  • 700 POSTS
No idea. Are there any applicable trouble codes? If it cranks good but won't start, have a helper crank it, while visually check for spark at the plugs. Use a gage and check fuel pressure. Got to start somewhere.
Jun 23, 2010 at 1:46 AM
BLUCIPHER
  • 7 POSTS
thx I guess I'll give it a shot. I can't imagine it's not something stupid. It was running great minutes before unhooking the battery!
Jun 23, 2010 at 2:06 AM
INTERNETMECHANIC
  • 700 POSTS
Did you check the fuses? A voltage spike is all I could think of?
Jun 23, 2010 at 2:31 AM
BLUCIPHER
  • 7 POSTS
actually no, it pissed me off so I stepped away from it lol.. that'll be the first thing I check when I get home from work, thx!
Jun 23, 2010 at 2:57 AM
BLUCIPHER
  • 7 POSTS
so I checked all the fuses and none are blown. its getting gas. someone suggested that the noise I heard could have been the anti theft mechanism? if it is, then how do I bypass it if it won't let me turn my own car on?
Jun 23, 2010 at 9:56 AM
INTERNETMECHANIC
  • 700 POSTS
Unless it is aftermarket, there is no security system. MOD didn't show it?
Jun 23, 2010 at 11:43 AM
BLUCIPHER
  • 7 POSTS
not sure, don't have one. But, every single time I unhook the battery, upon reconnecting it, there is a high pitched sound that sounds like its coming from in the steering column or in the dash. Its a contiunous sound until I turn the key on. Then is doesn't do it again unless I unhook the battery and rehook it again.
Jun 23, 2010 at 11:13 PM
BLUCIPHER
  • 7 POSTS
so I still cant figure out whats wrong!! I checked the engine codes and it just repeated 12 which means it found no issues. For s**** and giggles I put a new battery in it. Upon connecting it I heard the beep again and also noticed a clicking sound that is in sync with the dome lights flashing on and off. This all goes away when I turn the key to on, but the car still just turns over w/o starting
Jul 8, 2010 at 2:10 AM
INTERNETMECHANIC
  • 700 POSTS
Did you ever visually check for spark at the plugs. Pull a spark plug wire, use known good plug or spark tester in the boot, ground metal part of tester to metal part of engine, engine cranking, watch for spark.
Use a gage to check fuel pressure, having some pressure isn't good enough. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one.
You might try some starter fluid, there are some safety issues with using a flamable spray, the safety issue is your responsibility. I take the air duct loose from the throttle-body, open the throttle valve, spray just a little in there, don't stand over the engine, do not work the throttle pedal, just turn the key to crank, see if the engine tries to start.
I can't help about the noise, don't know what it is? Check the relays, usually you can put your fingers on the relay and feel if it is clicking?
Jul 8, 2010 at 2:27 AM
BLUCIPHER
  • 7 POSTS
well I couldnt get a fuel pressure gauge yet but, I just replaced the pick up and it gets great spark at the plug. I took oput the number 1 plug and got it to top dead center and checked the timing, right on. I checked the fuel lines and saw that the one on the driver side was getting a lot of fuel when I turned the key on. The passenger side wasn't getting any so I assumed that was the return?
Jul 14, 2010 at 10:57 AM
JDL
  • 16,098 POSTS
If you check fuel pump volumn on the return side, if it will fill up a tall-boy beer can in under 30 seconds, I call it good volumn. Maybe not very scientific, an empty beer can is usually the only empty container I can find. lol
Jul 15, 2010 at 4:14 AM
