1986 Chevy Camaro electrical short
1986 CHEVROLET CAMARO
98,000 MILES • V8 • 2WD • AUTOMATIC
GILLIGANXR35
my camaro has always had an electrical problem. When I turn on my headlights or my fan switch ( thermostat went out, used manual switch to turn on fan ) the battery level indicator drops drastically. Before my Father in law gave it to me it did the same thing when the a.c. worked and was turned on. How do I find the problem and fix it?
Dec 13, 2009 at 2:31 PM
ERNEST CLARK
  • 1,730 POSTS
First, your dash board gauge only measures battery voltage when the engine is "Off". Once you start the engine, the gauge is now reading voltage from the alternator.
If the gauge needle is dipping drastically every time you turn something on, then your alternator or voltage regulator is faulty.
But first, you need to make sure that your ground strap is tight and not corroded. (This is a metal strap running from your engine block to any point on the frame) Then check your batter cables for corrosion, as well as the negative cable to where it terminates either on the engine block or frame.
Once you eliminate these as possible causes, then it is more than likely you have a weak alternator/voltage regulator.
***The Key to electrical problems***
If only one accessory is causing a large dip in voltage, then it's that particular accessory.
If many, or all, accessories are causing a large dip in voltage, then the problem is with whatever is supplying the voltage to begin with. (Or the cables)
Dec 31, 2009 at 6:11 AM
