1985 Chevy Camaro
SAMSEL
  • 1985 CHEVROLET CAMARO
1985 Chevy Camaro V8 Automatic
Ignition switch will not go to lock position. New ignition switch installed.
Thursday, October 14th, 2010 AT 10:08 PM
HMAC300
  • 48,601 POSTS
You may not have installed it right. And you may have to reinstall it. But try this first. Turn teh key to start and then release it. Then see if it will go back. If not then you'll need to take it back out and reinstall it. To reinstall it turn the switch to the on position then push the cylinder in and move to start. Then it should work right.
Friday, October 22nd, 2010 AT 7:25 PM
