1982 Chevy Camaro Fuel System
PERCYAK
  • 1982 CHEVROLET CAMARO
  • V8
  • 97,000 MILES
Accelerate to speedlimit (40mph). When letting off the accelerator car dies. After prolonged period may start. Engine not hot.
Fuel Pump?
System is fuel injection.
Tuesday, June 30th, 2009 AT 11:24 AM
JDL
  • 16,098 POSTS
Hello, after it dies, is the choke valve closed, engine won't run with the choke valve completely closed. If you try starter fluid in the intake, will it start? When it refuses to restart, engine cranking, do you have spark at the plugs? Some of these carbs, I can remove the air-horn without too much trouble, I look to see if there is any fuel in the float-bowl?
I didn't ask if the vehicle had a carb or fuel injected?
Tuesday, June 30th, 2009 AT 11:50 AM
