1980 Chevy Camaro 1980 camaro
1980 CHEVROLET CAMARO
JOE ANSON
Electrical problem
1980 Chevy Camaro V8 Two Wheel Drive Automatic 89k miles
hey, i own a 1980 z28 camaro and have put many different parts on it due to fault and ware. the other morning i went out to start my car and i turned the key to start it and no noise even appeared. my radio turned on and my battery gauge read the correct voltage but when i turned the key all the way to start nothing happen. I have also replaced the starter in it once already just this summer and cant see how thats the problem. can you help me?
Oct 2, 2008 at 10:38 AM
IMPALASS
  • 3,112 POSTS
If you are sure it isn’t the starter then it may be the ignition switch. You can have Auto Zone bench check the starter for free. I could be locked up. But if it spins freely then again, it may be the ignition switch. That is located on the steering column.
Oct 4, 2008 at 7:42 PM
