1999 Chevrolet Blazer Transfer Case Noise
NHGUY03235
I have a 99 chevy blazer, 4.3 4wd auto. I just finished replacing the fuel pump module (pain but no big deal) I started the truck up and started to drive away when it sounded like the front drive shaft was about to fall out . The noise sounds like it is coming from the transfer case, 4wd switch is working (can spin driveshaft by hand in 2wd but not when swithched into 4wd) sounds like a u-jnt with no needle bearings left but all feels tight. What could I have possibly done in replacing the fuel pump that could have caused a drive train problem???????? Thanks in Advance :?
Aug 9, 2007 at 12:11 PM
MERLIN2021
  • 17,250 POSTS
Pobably nothing...but GM uses an epoxy so hold the u-joint in the yolk, making checking the u-joit tricky. A squeeking sound that speeds and slows with speed is a good sign, other than that use a prybar and use the yolk as a pry point see if you get ANY movement. if yes replace the joint.
Aug 10, 2007 at 7:16 AM
Suggested Repair
The fuel pump replacement likely did not cause the noise. Check the U-joint by using the yoke as a pry point; if there is any movement, replace the joint. GM epoxy can make U-joint inspection difficult.
Conversation Summary
The owner of a 1999 Chevrolet Blazer heard driveline noise that seemed to come from the transfer case immediately after replacing the fuel pump. The 4WD switch still worked, and the joints felt tight. The expert said the pump work probably caused nothing and advised checking the U-joint for play at the yoke, then replacing it if any movement is found.
