HI, I HAVE A 97 CHEVY BLAZER. AND AM HAVING PROBLEMS STARTING IT UP. IT WILL SPUTTER SERVERAL TIMES BEFORE ACTUALLY STARTING UP. SOMETIME I'LL EVEN GET A QUICK PISTON SLAP AT STARTUP TOO. I ALSO GET A STRONG SMELL OF RAW FUEL EVERYTIME I TURN THE TRUCK OFF. ANYWAYS AFTER STARTING IT UP AND LEAVING IT RUN FOR WHILE I'LL JUST TURN IT OFF AND WAIT A FEW MINUTES THEN TURN IT BACK ON AND IT WILL STARTUP JUST FINE WITH NO PROBLEMS AT ALL. BUT IF I LEAVE IT OFF FOR ABOUT 30 TO 60 MIN. AND THEN TRY TO STARTUP AGAIN IT WILL DO THE SAME THING AGAIN SPUTTER SERVERAL TIMES BEFORE STARTING UP AGAIN. I HAVE ALREADY CHANGE ALL MY SPARK PLUG AND CABLE, IDLE AIR CONTROL VALVE, AIR FILTER, OIL CHANGE, FUEL FILTER, NEW FUEL PUMP AND THE LIST GOES ON. AND THIERS NO CHECK ENGINE LIGHT EITHER JUST SO YOU KNOW. PLEASE LET ME KNOW WHAT THE PROBLEMS IS. THANKS PLEASE WRITE SOON
SPONSORED LINKS
Sunday, August 19th, 2007 AT 9:47 AM
