Rubbing noise from wheels
CHEVROLET BLAZER
MEATY
  • 6 POSTS
I have a 1994 S-10 Blazer 4x4. I am hearing a rubbing noise when I am moving about 25 MPH when I am off of the gas pedal. Does a 4x4 model need a non-drive axle wheel bearing \ repack seals service? If so how much would this cost for the front and and how much for the bearings and seals in the rear (drive) axle?
Jul 24, 2007 at 5:18 PM
TOTALLYLOST
If it is a squeeking noise you hear, its a tell tale on the brakes telling you to change then, thats what happened to my. you will only hear the noise when you're moving but not when your on the brakes or idleing.
Aug 14, 2007 at 10:08 AM
