I have a 1997 chevy blazer 4.3 75000 miles. I recieved a Po300 Code. My mecanics said that they cant figure out what actually is going on. They know what the code means. I drive to college and about 70 mph on the interstate. By the time I drive 100 miles, my rpms are normal at 2200. they like to jump up too 2500 when driving at 70mph after a period of time. I get bad gass millage. Im guessing its the plugs and wires. I dont know for sure. My rpm tach jumps around between 2400-2600 while driving that fat and it seams like its chugging? Plz help Thanks
1997 Chevy Blazer P0300 Misfire
Next would be spider assy for the fuel inection or a fuel line that ruptures underneath the intake.
Weak fuel pump would be the third suspicion.
[quote:fe8d19eee1="Barker_Chevy"]Hey,
I have a 1997 chevy blazer 4.3 75000 miles. I recieved a Po300 Code. My mecanics said that they cant figure out what actually is going on. They know what the code means. I drive to college and about 70 mph on the interstate. By the time I drive 100 miles, my rpms are normal at 2200. they like to jump up too 2500 when driving at 70mph after a period of time. I get bad gass millage. Im guessing its the plugs and wires. I dont know for sure. My rpm tach jumps around between 2400-2600 while driving that fat and it seams like its chugging? Plz help Thanks[/quote:fe8d19eee1]
Suggested Repair
Start with the distributor cap and rotor. If the random misfire continues, inspect the spider fuel-injection assembly and look for a ruptured fuel line under the intake, then test for a weak fuel pump.
Conversation Summary
The owner of a 1997 Chevrolet Blazer 4.3 with 75,000 miles reported a P0300 random-misfire code, poor fuel economy, and highway RPM rising from about 2200 to 2500-2600 with a chugging feel after extended driving. Injector cleaning and a fuel-system cleaner helped only slightly. A service writer said P0300 has many causes and first suspected the distributor cap and rotor, followed by the spider injector assembly or a fuel line leaking under the intake, then a weak fuel pump. Another reply suggested checking the brake-light switch, transmission connections, and overdrive solenoid.
