I have a 96 Blazer, acts as though it is flooding, I've changed injectors, fuel regulator, plugs, wires cap & rotor, MAP sensor, catalytic convertor, no help. Fuel consumption has gone from 20mpg to 10 mpg. I also had the PCM reprogrammed. It's as though the PCM is receiving info to send more gas. I also can only get 1 code 300 (random misfire) I need the solution, can you help?
SPONSORED LINKS
Monday, October 1st, 2007 AT 5:04 PM
