On 1988 blazer s10. Drivers side door lock is broken, can it be replaced, by me, at home. Best place to order replacement?
May 27, 2007 at 9:46 AM
MIKE H R
CERTIFIED EXPERT
you can replace it yourself or have someone do it, raise the window completly, remove the door trim panel, detach the lock cylinder linkage, slide the retainer forward, then the lock can ber removed from the outside. installation is reverse of removal.
