2003 Chevy Blazer temp and directional reading
MORRISW
  • 2003 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 110,326 MILES
The temp reading is off by about 30 degrees. What can I do to fix this problem.
Wednesday, October 14th, 2009 AT 11:19 AM
JDL
  • 16,098 POSTS
Welcome, are you talking about the gage reading? Did you take an independent engine temp reading, compare to gage reading? Maybe a problem with dash cluster, sending unit, wiring circuit, thermostat?
You said the reading is off 30 degrees, high or low?
Wednesday, October 14th, 2009 AT 11:45 AM
MORRISW
That is 30 degrees high
Wednesday, October 14th, 2009 AT 1:01 PM
JDL
  • 16,098 POSTS
If you think the reading is accurate, check the thermostat and coolant flow through the radiator.
Wednesday, October 14th, 2009 AT 1:35 PM
MORRISW
This has nothing to do with the engine. It is the reading of the outside temp and the direction that you are driving
Wednesday, October 14th, 2009 AT 1:40 PM
JDL
  • 16,098 POSTS
Sorry, my bad, I found this wiring info.
https://www.2carpros.com/forum/automotive_pictures/170934_ambient_temp_sensor_1.jpg
Not sure if you can read it. If I magnify it too much, I can't get the whole diagram on the screen. The ambient temp sensor is front center of vehicle, behind fascia. The higher the temp, the lower the resistance reading across the sensor. At 81 degrees the min ohms spec is 11150, max ohms spec is 11250 across sensor. The problem could be the sensor--wiring circuit--or driver information center.
Wednesday, October 14th, 2009 AT 2:33 PM
MORRISW
Thanks
Wednesday, October 14th, 2009 AT 3:17 PM
Related General Content
