2003 Chevy Blazer misfire
RHANNA0605
  • 2003 CHEVROLET BLAZER
  • 6 CYL
  • 98,000 MILES
I have a misfire on cylinders 1 and 6.I think those are the front and back cylinders on the passenger side correct? I replaced both plugs and it still wont go over 3500 RPM aside from replacing the plug wires, what else should I check and what could have fouled out 2 wires?
Tuesday, November 2nd, 2010 AT 2:33 PM
WRENCHTECH
  • 20,761 POSTS
That is the front cylinder on the driver's side and the back one on the passenger side.
You need to do more testing and lets parts changing. Use a spark tester or scope to find out if you problem is ignition or not. If the cap and wires are due for replacing, do that anyway.
Tuesday, November 2nd, 2010 AT 3:01 PM
