The first sound could be almost anything from a vacuum leak on to a bad fan clutch. Does it do it all the time? Only when cold? Any other noises at the time?
Brake problem sounds like the ABS sensor problem that is caused by rust under the sensors. It causes the ABS to activate because of a weak signal from the sensor. It's not a hard fix if your mechanically inclined.
SPONSORED LINKS
Thursday, December 11th, 2008 AT 10:20 PM
