My vehicle is a 2002 Jimmy. If I engage the 4 wd on the fly at speeds greater than approx 30 mph, sometimes what happens is that the next time I try to go into 4 hi after shutting it off, it will not work. What I was told to do by a former GM mechanic is to disconnect the battery for 20-30 secs to reset computer. This worked on the 3 occasions where I had this problem. Now I only swith to 4 Hi at low speeds or else at stop signs or street lights. Hope this helps somebody.
Friday, May 14th, 2021 AT 12:28 PM
