Other Category problem
2001 Chevy Blazer V6 Four Wheel Drive Automatic 72000 miles
when driving the heat works fine but when stopped the water temp goes up and cool air comes out
Thursday, December 6th, 2007 AT 11:18 AM
BMRFIXIT
MECHANIC
Check coolant level. Do it when truck cold open radiator cap top off start put heat on max Run for 5 to 10 min top off. Be careful antifreeze can get very hot and will burnt
SPONSORED LINKS
Thursday, December 6th, 2007 AT 5:21 PM
KEN L
MASTER CERTIFIED MECHANIC
Yep, I have seen the coolant level below and cause this issue, here is a video and two guides to help fix the problem.
