All the system problems you listed are based on the electrical system. If that system is having a problem it could lead to several misc. Problems occuring all at once.
I would suggest to start simple and have the electrical system thoroughly inspected. ( Battery, cables, alternator, and regulator if separate from alt. ) Also be aware that the computer requires a properly running electrical system and ground connection to operate correctly. Don't assume it must be the computer.
Note : The computer can be damage if exposed to excessive electrical current. Such as improper jump starting or ignition coil/wire arcing.
This is a good start for a random electrical problem on a vehicle with high miles and age. Always start simple / inexpensive and then work to complicated / expensive. Always remember that the repair shop should be able to explain in understandable terms why your problem occured.
Thursday, December 3rd, 2009 AT 10:06 AM
