2001 Chevy Blazer
ARMANDONC1
  • 2001 CHEVROLET BLAZER
Engine Performance problem
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic 92K miles
I own a 2001 Chevrolet Blazer 4 wheel drive 4.3 liter engine. I am also the original owner. This vehicle starts up perfectly okay and smooth. You can put a dime on the engine and it will not fall off. However, when vehicle is put into drive and I start to accelerate the vehicle has no power at all. It will barely reach 25 mph. I took the vehicle to dealer and was advised that it needed a catalytic converter. I replaced it and the problem still exists. I also replaced spark plugs, distributor cap, and rotor. The problem still exists. I replaced MAP sensors, MAF sensors, air flow sensor, and EGR valve. I also took fuel pressure readings and they checked out okay. The problem still exists. I was advised that there could be probable cause that the upper intake or lower intake manifold gaskets may be faulty. I also replaced these and the vehicle still has no pickup at all when in drive and during acceleration under load. Can anyone please advise as to what can possibly be the probable cause to this problem? As my mechanical abilities are exhausted. Please advise and help.
Sunday, April 20th, 2008 AT 8:20 PM
KEVIN12881
  • 336 POSTS
Are yous brakes binding?
Sunday, April 20th, 2008 AT 9:03 PM
ARMANDONC1
I do not think they are binding, the chevy dealer checked the brakes because I also mentioned to them when I took it in that the emergency brake pedal would not click and hold down. They told me that this pedal works with vacum and that it was caused by low vacum. Could this be true, and can this be afected by the overal problem?
Monday, April 21st, 2008 AT 3:17 AM
DENNYP
  • 1,824 POSTS
Are there any trouble codes stored in the computer?
Monday, April 21st, 2008 AT 9:17 PM
