Those are electronically controlled. Usually if they stay engaged its the module located under the passenger side kick plate under the dash. However you may be looking at a transfer case issue so best bet is bring it to a garage. You can rule out the push button select switch, thats definatly not the cause.
SPONSORED LINKS
Thursday, August 26th, 2010 AT 9:21 PM
