2000 Chevy Blazer Vehicle died and won't turn over
SHAMALICIOUS
  • 2000 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 260,000 MILES
Ok so the problem with my blazer is the battery light was on for a while, thought nothing of it till the weekend but when I was on my way to work it started losing a lot of power, everything turned off lights, dash board, everything in the vehicle, by the time I got to work the Blazer would barely drive, made a "chugging" sound and after I shut it off it wouldn't start again. I got it towed home and later on that night when I checked it all the lights and stuff would come on but it wouldn't turn over not even a little bit, I'm wondering what this could possibly be, I am thinking alternator but I am just wondering if there is a more definate way to tell, because I thought it would be able to start off the battery at least for a minute if it was the alternator, but I can't even get a tiny little bit of a crank
Please Help
thank you
Friday, January 30th, 2009 AT 7:17 PM
Start by getting the battery and alternator load tested and then report back for more
Saturday, January 30th, 2021 AT 9:02 AM
SHAMALICIOUS
I took the alternator and the battery off and took them in to get load tested, ends up it was just the battery. I have never seen things die like that on a vehicle when the battery went, only the alternator but thats why I came to you guys, thank you very much.
You've learned something here-spread the word out about 2carpros helping people like you-Good Luck
SHAMALICIOUS
So I replaced the battery in the blazer and it started right up, it drove for two days and then when I woke up this morning I went out to start it and it wouldn't start again, I checked everything over to make sure nothing was left on over night which it wasn't. And now I am trying to boost the vehicle and can't get it to boost. I'm wondering what else this could possibly be?
