2000 Chevy Blazer Maybe fuel injector problem???
2000 CHEVROLET BLAZER
126,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZMAN6988
Hi I have a 2000 Blazer Traiblazer edition with 4.3 automatic four wheel drive with 126000 miles. The problem is when I crank the engine everything is fine but when I go to leave then engine wants to stumble between shifts 1-2 then 3-4 but not drive or over drive. It does not matter weither you let it warm up or not or if it's hot or cold outside it only does it for like 5-8 miles then stops. I thought it might be a Torque converter problem but the engine still stumbles in neutral and park. Also at 60 mph it feels like the TPS is bad by stumbling and hesitating but I checked it and the voltage is correct all the way thru WIO. I have replaced plugs, plug wires, air and fuel filter, cap and rotor, thermostat, and CAT converter. Fuel pressure reads @63 psi thru idle and rev. I just don't have a clue anymore, so maybe you guys can help me please. Thanks Chas
May 9, 2009 at 4:03 AM
RHALL77
  • 3,361 POSTS
you may have an issue with fuel volume. you may have the fuel pressure but if the volume isnt there it wont run correctly. do you have a check engine light on? you could also have a problem with the maf sensor. try disconnecting it and driving the vehicle and see if it is better.
May 11, 2009 at 6:35 AM
ZMAN6988
No engine light I had it scanned yesterday but nothing showed up. I will try uplugging thee MAF I didn't think about that. Thanks I check back with you after I try it out.
May 12, 2009 at 4:21 AM
