2000 Chevy Blazer EMERGENCY BRAKE
OXYBLOND
When I drive the blazer it seems like I am driving with the emergency brake on. Can you please give me some ideas what it could be. Thanks
Apr 7, 2010 at 6:21 AM
CARADIODOC
  • 34,400 POSTS
Park on a slight incline, put it in neutral, then release the brake pedal and see if it creeps ahead on its own. If it doesn't, suspect sticking rear parking brake cables or a sticking front caliper. Put a block of wood downhill a few inches in front of one of the tires in case the sticking brake lets go, then crawl underneath and flex the parking brake cables. That will usually make a sticking cable release. if it does, have that cable replaced.
If neither cable is stuck, jack the front tires off the ground and look for one that you can't spin by hand. If a caliper is sticking, it is customary to replace both of them at the same time to maintain even side-to-side braking.
caradiodoc
Mar 19, 2021 at 5:20 AM
