will not shift out of 2 wheel drive
KKACHH
my blazer will not shift out of 2 wheel drive
Oct 1, 2009 at 8:21 AM
AJVANDYKE
  • 36 POSTS
Most of the time when I have came across this problem its not the shift motor or the switch that is the problem (Although I'm not completely ruling them out). Usually the problem is either a short in the wiring harness near the T-case if you hit a rock or a tree branch. Or one of the speed sensors on the T-case is bad. Or it can even just be some moisture in the connection.
Apr 25, 2021 at 4:21 AM
