1999 Chevy Blazer Swapping cranks
JHENDO
  • 1999 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 118,000 MILES
I want to take the crank from my old 95 blazer and swap it to my 99 blazer. I spun a bearing in the 99. The 95 is good. Both blazers are 4.3 motors. Are there any difference in the two years of cranks?
Thursday, August 26th, 2010 AT 3:57 PM
MADMIKE1735
  • 951 POSTS
Both cranks should be identical. I recommend sending both to a machine shop, and have them further matched up. Also, while at the machine shop have your 95 crank turned, and order oversized rod/main bearings. Your this far into it, why use the old bearings you know? Turning the crank shouldnt be to expensive, and new bearings will be required. Also, have check into the bearings. Its been a while so im not sure if your replacement bearings are oversized, or undersized. Tell your local parts dealer (i recommend NAPA) how many thousandths the crank was machined, and they will know what bearings you need. Hope this helps.
Friday, September 24th, 2010 AT 9:28 PM
Related General Content
