When I turn the car off and take the key out, about 15 seconds later the blue high beam indicator light comes on and runs the battery down. Why?
Oct 10, 2008 at 9:21 PM
KERENSELF
MEMBER
I would suspect either a wiring issue or a bad headlight or dimmer switch.....accurately diagnosing the problem will require a wiring diagram and multi-meter or test light.
In the meantime, I would disconnect the battery when you park the truck at night to ensure you will have power to start it the next morning.
