1999 Chevy Blazer Blazer makes noise when going over bumps
1999 CHEVROLET BLAZER
141,000 MILES • 6 CYL • 4WD • AUTOMATIC
LUKEVAN
  • 10 POSTS
My '99 Blazer started to make a "slap-tunk" noise after I put brand new Cooper Discoverer radials on it. It has 4-wheel disc brakes and did it when I went down the road and increased with my speed. Now, it just does it when I go over a bump. It also squeaks like something needs to be greased when I step on the brakes hard(It does this when its stopped). Please respond, it is greatly appreciated!
Oct 30, 2008 at 1:30 AM
SWILLIAMS
  • 597 POSTS
Do you feel a bump through the seat when you hear the noise? If so check the torsion bar mounts and cross member. The rubber tends to fail and cause noise. The other option is the ball joints. Because it happened after new tires it could also be that they were stressed.
Oct 30, 2008 at 4:29 AM
