Check for spark which I would expect that you have and if so need to check fuel pressure
very common for the fuel pump to fail
fuel pump will continue on working but will not provide the pressure needed
use a fuel pressure gauge and check fuel pressure, any reading under 60 PSI pump is no good and need to be replaced
SPONSORED LINKS
Sunday, October 17th, 2010 AT 8:50 AM
